yum update previously run and system previously rebooted
[root@efa spamassassin]# yum update
Setting up Update Process
epel/metalink                                            | 5.2 kB     00:00
 * base: centos.01link.hk
 * epel: ftp.cuhk.edu.hk
 * extras: centos.01link.hk
 * rpmforge: mirror.oscc.org.my
 * updates: centos.01link.hk
base                                                     | 3.7 kB     00:00
extras                                                   | 3.4 kB     00:00
rpmforge                                                 | 1.9 kB     00:00
updates                                                  | 3.4 kB     00:00
No Packages marked for UpdateCode: Select all
[root@efa ~]# EFA-Update -check
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are running EFA version EFA-3.0.0.8
[EFA] Latest version update is EFA-3.0.0.9
[root@efa ~]# EFA-Update -update
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.0.9
Your system has an updated kernel, but you are not running
on the latest kernel.  Please restart your system and run
EFA-Update after restart.
[root@efa ~]# uname -a
Linux efa.domain.local 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/LinuxCode: Select all
[root@efa spamassassin]# /var/EFA/update/EFA-update-script
base                                                     | 3.7 kB     00:00
EFA-Update after restart.Code: Select all
[root@efa ~]# uname -r
[root@efa ~]# grep -m 1 CentOS /boot/grub/menu.lst
title CentOS (2.6.32-573.22.1.el6.x86_64.debug)reboot again and make sure the correct kernel is selected.
that's funny. I didn't get a chance to select which kernel to boot.
further checking: my booted kernel was the second entry in the grub kernel list, not the first. The update check was looking for the first entry. As a result, the update check was failing.
Quick fix, reconfigure the boot list to make the first entry the kernel I need to boot from and continue with the update.
Not sure why my kernel entry in the grub list was different from the default - something I previously did, or some artifact from previous upgrades/updates. Solution(?) pay attention to the "default=X" line in the grub file and then grep for that particular line? Or just ignore it because my installation is weird. I think I'll go with weird.
fixed the grub problem, now rerun the update
[root@efa ~]# /var/EFA/update/EFA-update-script
Error: Package: 2:postfix-perl-scripts-2.6.6-6.el6_7.1.x86_64 (@updates)
           Requires: postfix = 2:2.6.6-6.el6_7.1
           Removing: 2:postfix-2.6.6-6.el6_7.1.x86_64 (@updates)
           Updated By: 2:postfix-3.0.4-1.efa.el6.x86_64 (EFA)
               postfix = 2:3.0.4-1.efa.el6
           Available: 2:postfix-2.6.6-6.el6_5.x86_64 (base)
               postfix = 2:2.6.6-6.el6_5
           Available: 2:postfix-3.0.3-2.efa.el6.x86_64 (EFA)
               postfix = 2:3.0.3-2.efa.el6
Update to Version 3.0.0.9 FAILED.  Updates cancelled.according to this post, remove the problem package
[root@efa ~]# yum erase postfix-perl-scriptsresult: failure again.
Transaction Check Error:
  file /usr/share/man/man3/XML::SAX::Base.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
  file /usr/share/man/man3/XML::SAX::Exception.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarchCode: Select all
rpm -e --nodeps perl-XML-SAX-Base
yum install perl-XML-SAX
/var/EFA/update/EFA-update-scriptI think the subject should either be "EFA Update Failure..." or "EFA Update Results..." in this case.
update result this time: third time lucky. update complete.
3.0.0.9 update is complete
All done
Thank you for using E.F.A.
[root@efa ~]# rebootSummary:
three problems preventing updates.
- two of them previously documented in the forums
- one of them appears "new" and is probably a problem specific to my installation for whatever reason
- each failure sends an "EFA Update Complete" message which is not technically correct
- last updated succeeded (of course) and everything appears to be working.
Oh, and thanks to you previous upgraders for having the problems and solving them. That certainly saved me a lot of time.
