My update from 3.0.0.8 to 3.0.0.9 is failing with the following error.
-> Finished Dependency Resolution
Error: Package: 2:postfix-perl-scripts-2.6.6-6.el6_7.1.x86_64 (updates)
           Requires: postfix = 2:2.6.6-6.el6_7.1
           Removing: 2:postfix-2.6.6-6.el6_5.x86_64 (@updates)
               postfix = 2:2.6.6-6.el6_5
           Updated By: 2:postfix-3.0.4-1.efa.el6.x86_64 (EFA)
               postfix = 2:3.0.4-1.efa.el6
           Available: 2:postfix-2.6.6-6.el6_7.1.x86_64 (updates)
           Available: 2:postfix-3.0.3-2.efa.el6.x86_64 (EFA)
               postfix = 2:3.0.3-2.efa.el6
Update to Version 3.0.0.9 FAILED.  Updates cancelled.
						3.0.0.9 Postfix update failing
Re: 3.0.0.9 Postfix update failing
Do you use those perl scripts?
They are not bundled with EFA....
Yes. Used for generating a report.
I will remove them and try the upgrade.
Removed the postfix-perl-scripts-2.6.6-6.el6_7.1.x86_64 and update went smooth.
Do you need these perl scripts?  If so, maybe I can build a new rpm for them.
No Thanks. I just copied the script to the new server and it runs without an issue.
regards
Yashodhan
						regards
Yashodhan
i am getting this error when i am upgrading:
Transaction Check Error:
file /usr/share/man/man3/XML::SAX::Base.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
file /usr/share/man/man3/XML::SAX::Exception.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
I fixed the error I had by manually removing the conflicting package (rpm -e) and then running the upgrade.
After snapshotting the machine in a scheduled downtime.
