Transaction Summary
Install      33 Package(s)
Total download size: 5.1 M
Installed size: 18 M
Downloading Packages:
Total                                           1.6 MB/s | 5.1 MB     00:03
Running rpm_check_debug
Running Transaction Test
Transaction Check Error:
  file /usr/share/man/man3/XML::SAX::Base.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
  file /usr/share/man/man3/XML::SAX::Exception.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
Error Summary
Update to Version 3.0.0.9 FAILED.  Updates cancelled.
All done
Thank you for using E.F.A.
Re: Update to Version 3.0.0.9 FAILED
Easy fix...
Then run update again.
sudo rpm -e --nodeps perl-XML-SAX-Base
sudo yum install perl-XML-SAX
3.0.0.9 update is complete
All done
Thanks for your very quick response.
						All done
@shawn
Same problem here. Your second line fixed it.
Had this problem also and your fix worked.
