Error during initial install: unexpected EOF while looking for matching '
Bugs in eFa 5
Alma Linux 9.4, minimal, fresh, install
From the /var/log/eFa/build.log
* snip *
Created symlink /etc/systemd/system/multi-user.target.wants/httpd.service → /usr/lib/systemd/system/httpd.service.
Created symlink /etc/systemd/system/multi-user.target.wants/php-fpm.service → /usr/lib/systemd/system/php-fpm.service.
Removed "/etc/systemd/system/multi-user.target.wants/crond.service".
Removed "/etc/systemd/system/multi-user.target.wants/chronyd.service".
Removed "/etc/systemd/system/multi-user.target.wants/firewalld.service".
Removed "/etc/systemd/system/dbus-org.fedoraproject.FirewallD1.service".
Configuring services...done
/usr/src/eFa/eFa-config-5.0.0.sh: line 183: unexpected EOF while looking for matching `''
/usr/src/eFa/eFa-config-5.0.0.sh: line 190: syntax error: unexpected end of file
Configuring eFaInit...
Configuring eFaInit...done
Build completed!
From /usr/src/eFa/eFa-config-5.0.0.sh, I can see the following with syntax highlighting turned on:
Screenshot 2024-07-25 at 13.05.29.png (174.31 KiB) Viewed 55082 times
Line 119 seems to be the issue as the command is not complete.
Edit: From branch 5.0.0-8, the line was previously:
sed -i '1i\\/usr\/sbin\/eFa-Init' /root/.bashrc
Edit 2: I commented out line 119, ran /usr/src/eFa/eFa-config-5.0.0.sh, rebooted and ran /usr/sbin/eFa-Init by hand.
Re: Error during initial install: unexpected EOF while looking for matching '
At the final stage of running /usr/sbin/eFa-Init
/usr/sbin/eFa-Commit: line 1066: unexpected EOF while looking for matching `''
/usr/sbin/eFa-Commit: line 1078: syntax error: unexpected end of file
[eFa] - Error initializing system!  Please try again...
That looks familiar...
 919   # Remove EFA-Init from console
 920   sed -i '/^if ! [ -z \"\$PS1\" ]; then \/usr\/sbin\/eFa-Init; fi/d" /root/.bashrc
I commented out line 920 and 921 and reran eFa-Init which seems to have worked. Rebooting...
Edit: rebooted. Everything appears to work as it should.
Thanks, fixing!
