MailWatch Recent message visualization empty
Posted: 21 Jan 2019 09:58
by gigabello
Hello fellows,
I have EFA-3.0.2.6 installed and all work fine except for visualization.
Since two weeks, when I click on "i" in recent messages for see sender, score etc etc, I see just few information, like you can see in attached image.
https://drive.google.com/open?id=1PywKN ... MmjycNLVEz
Before this issue, I saw all I need for valutate the message.
have you any idea about?
Re: MailWatch Recent message visualization empty
Posted: 21 Jan 2019 10:29
by gigabello
already try this solution
viewtopic.php?f=13&t=3078
nothing is changed
Posted: 07 Feb 2019 13:04
by tecumseh
I have the sem problem. Fresh installation on ESXI.
Anybody?
Posted: 07 Feb 2019 22:43
viewtopic.php?t=3311
viewtopic.php?t=2928
clam is not running due yara related errors and the free geoip is not available anymore. Just read the 2 posts above how to solve it
and please report back success or failure
after a fresh install or upgrade to 3.0.2.6 you may need to add symlink back for backward compatibility
# Add init.d symlink back for backward compatibility
# ln -s /etc/init.d/mailscanner /etc/init.d/MailScanner
see
viewtopic.php?f=13&t=2892&p=11492#p11492
Posted: 08 Feb 2019 14:49
by tecumseh
Thanks! It works!
Posted: 11 Feb 2019 15:36
by cstibor99
We have same problem with new installation.
(EFA-3.0.2.5 and EFA-3.0.2.6)
I tried add the new symlink, but this solution doesnt work for us.
When I try to click on (i) in recent messages (or quarantined messages) I see just few information, like "gigabello" original bug report.
The system message from postfix, displays correctly, but all incoming messages are not display details.
Can anybody help me?
Posted: 11 Feb 2019 19:01
Did you read all posts mentioned? As you have a new installation, you should.
Posted: 12 Feb 2019 09:53
by cstibor99
Hi!
I made all of 3 solutions:
-geoip update
-clam update
-new symlink
It's working now, Thanks!
