Hello fellows,
I have EFA-3.0.2.6 installed and all work fine except for visualization.
Since two weeks, when I click on "i" in recent messages for see sender, score etc etc, I see just few information, like you can see in attached image. https://drive.google.com/open?id=1PywKN ... MmjycNLVEz
Before this issue, I saw all I need for valutate the message.
clam is not running due yara related errors and the free geoip is not available anymore. Just read the 2 posts above how to solve it
and please report back success or failure
after a fresh install or upgrade to 3.0.2.6 you may need to add symlink back for backward compatibility
# Add init.d symlink back for backward compatibility
# ln -s /etc/init.d/mailscanner /etc/init.d/MailScanner
see viewtopic.php?f=13&t=2892&p=11492#p11492
We have same problem with new installation.
(EFA-3.0.2.5 and EFA-3.0.2.6)
I tried add the new symlink, but this solution doesnt work for us.
When I try to click on (i) in recent messages (or quarantined messages) I see just few information, like "gigabello" original bug report.
The system message from postfix, displays correctly, but all incoming messages are not display details.
