ClamAV Vulnerabilities
sebastian.savard
Re: ClamAV Vulnerabilities
I'm assuming this is an update that we'll have to perform on our own systems, as 3.0.2.6 is the last of version 3. Has any successfully upgraded?
eFa uses the clamav from epel, so hopefully it'll get updated soon and all you will need to do is run a yum update.
how can I check if the update is available?
from the efa command prompt:
sudo yum updateRe: ClamAV Vulnerabilities
Thanks. But is that really only the check for updates? Or will there be updates installed via the command?
That command will check for updates, and if there are any, will ask you to confirm before updating. If you say "n", then nothing further will happen.
Still ClamAV 0.99.2
Somebody an idea why there is still no update?
updated
All good things come to those who wait.
clamav x86_64 0.99.3-8.el6 epel 4.3 M
clamav-db x86_64 0.99.3-8.el6 epel 155 MRe: ClamAV Vulnerabilities
Do I need to reboot the system after clamav-update?
Run
Software version from DNS: 0.99.4
WARNING: Local version: 0.99.3 Recommended version: 0.99.4
Sometimes good things come to those who wait a bit longer....
freshclam -vWARNING: Your ClamAV installation is OUTDATED!
dwmp: no. the necessary services will be restarted.
henk:
henk:
Hmmm… my clamav is still on 0.99.2 but yum update won't server a newer one:
Trying to yum update, also doesn't work:
I tried without mirrors, clean yum's cache and DB, but to no avail. Any other idea, anyone?
[root@efa yum.repos.d]# yum list clamav
* EFA: dl.efa-project.org
* base: ftp.rz.uni-frankfurt.de
* epel: mirror.de.leaseweb.net
* extras: ftp.rz.uni-frankfurt.de
* remi-php72: rpms.remirepo.net
* remi-safe: rpms.remirepo.net
* updates: mirror.checkdomain.de
Installed Packages
clamav.x86_64 0.99.2-3.el6 @epel
[root@efa yum.repos.d]# yum update clamav clamav-db
Setting up Update Process
* extras: artfiles.org
* updates: centosmirror.netcup.net
No Packages marked for UpdateRe: ClamAV Vulnerabilities
What is your EFA version?
on versions below 3.0.26 yum.conf will exclude several packages from updating.
If you are on the latest version, remove them and run: yum check-update
same problem here, clamav is 0.99.2 but "No Packages marked for Update" (EFA 3.0.2.6)
Seems related to the epel repo used. Did you check /etc/yum.conf?
Otherwise just wait a bit longer till they update the repo. I don't know if switching the epel repo is a good idea.
[root@sansspam ~]# yum list clamav
* base: mirror.widexs.nl
* epel: fedora.cu.be
* extras: centos.mirror1.spango.com
* mariadb: ftp.nluug.nl
* remi-php72: mirror.netweaver.uk
* remi-safe: mirror.netweaver.uk
* updates: mirror.yourwebhoster.eu
Installed Packages
clamav.x86_64 0.99.3-8.el6
Available Packages
clamav.i686 0.99.3-8.el6
#exclude=kernel* postfix* mailscanner* MailScanner* clamav* clamd* open-vm-tools*[root@sansspam ~]# yum list clamav
Installed Packages
Available Packages
Hi henk,
thanks, that solved it.
Thanks,
budy
Thanks,
budy
so that means, if we don't want to switch epel repo, we still have to wait?
Or is it necessary to delete "clamav*" and/or "clamd" entries from the yum.conf file?
BR
dwmp
BR
dwmp
Hi dwmp.
Forget the remark about switching repos.
yum check-update“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
hi henk,
thanks for your reply! Sorry for asking silly questions, but by removing, you mean deleting the entries for clamav and clamd from the yum.conf file?
So that the config file looks like that:
#exclude=kernel* postfix* mailscanner* MailScanner* open-vm-tools*Re: ClamAV Vulnerabilities
the # on the start of the line already means : this line is comment. The rest of the line is ignored.
Running yum check-update will show you the packages to be updated.
No result means: packages already up to date.
Do not change yum.conf if you are not on E.F.A. 3.0.2.6. And always make backups/snapshots before you update.....
clamav-db.x86_64 0.99.4-1.el6 has landed
Hi henk,
thank you!
Im running on EFA 3.0.2.6. When executing "yum check-update" I get no clamav-package.
Still version ClamAV 0.99.2 is installed.
What do I have to do?
BR
dwmp
thank you!
BR
dwmp
