MailWatch Recent message visualization empty
gigabello
Post by gigabello »
Hello fellows,
I have EFA-3.0.2.6 installed and all work fine except for visualization.
Since two weeks, when I click on "i" in recent messages for see sender, score etc etc, I see just few information, like you can see in attached image.
https://drive.google.com/open?id=1PywKN ... MmjycNLVEz
Before this issue, I saw all I need for valutate the message.
have you any idea about?
gigabello
Re: MailWatch Recent message visualization empty
Post by gigabello »
already try this solution
viewtopic.php?f=13&t=3078
nothing is changed
tecumseh
Post by tecumseh »
I have the sem problem. Fresh installation on ESXI.
Anybody?
viewtopic.php?t=3311
viewtopic.php?t=2928
clam is not running due yara related errors and the free geoip is not available anymore. Just read the 2 posts above how to solve it
and please report back success or failure
after a fresh install or upgrade to 3.0.2.6 you may need to add symlink back for backward compatibility
# Add init.d symlink back for backward compatibility
# ln -s /etc/init.d/mailscanner /etc/init.d/MailScanner
see
viewtopic.php?f=13&t=2892&p=11492#p11492
tecumseh
Post by tecumseh »
Thanks! It works! :D
cstibor99
Post by cstibor99 »
We have same problem with new installation.
(EFA-3.0.2.5 and EFA-3.0.2.6)
I tried add the new symlink, but this solution doesnt work for us.
When I try to click on (i) in recent messages (or quarantined messages) I see just few information, like "gigabello" original bug report.
The system message from postfix, displays correctly, but all incoming messages are not display details.
Can anybody help me?
Did you read all posts mentioned? As you have a new installation, you should.
cstibor99
Post by cstibor99 »
Hi!
I made all of 3 solutions:
-geoip update
-clam update
-new symlink
It's working now, Thanks!
