firewall not accesable for root in Webmin
doggy101
Post by doggy101 »
Hi All,
trying to configure the IPtables firewall within webmin for additional security.
When I add the module IP tables i get "Access denied : User root is not allowed to use the Linux Firewall module"
does anybody know where to fix that?
Re: firewall not accesable for root in Webmin
Yep, having same problem...troubleshooting.
Log into Webmin
Go to Webmin --> Webmin Users
Click on root near the top
Expand Available Modules
Check Linux Firewall
Refresh Modules in the lower left corner.
doggy101
Post by doggy101 »
thanks solved :-)
