Hi All,
trying to configure the IPtables firewall within webmin for additional security.
When I add the module IP tables i get "Access denied : User root is not allowed to use the Linux Firewall module"
does anybody know where to fix that?
						firewall not accesable for root in Webmin
Re: firewall not accesable for root in Webmin
Yep, having same problem...troubleshooting.
Log into Webmin
Go to Webmin --> Webmin Users
Click on root near the top
Expand Available Modules
Check Linux Firewall
Refresh Modules in the lower left corner.
thanks solved
