Clearly I'll need to replace my aging Centos7 install of Efa but until I have time I'm seeing this error on update.
Failed to check for updates with the following error message:
Failed to build transaction: 1:mariadb101u-devel-10.1.41-1.el7.ius.x86_64 requires mariadb101u-libs(x86-64) = 1:10.1.41-1.el7.ius
Error: Package: 1:mariadb101u-devel-10.1.41-1.el7.ius.x86_64 (@ius)
Requires: mariadb101u-libs(x86-64) = 1:10.1.41-1.el7.ius
Removing: 1:mariadb101u-libs-10.1.41-1.el7.ius.x86_64 (@ius)
Obsoleted By: 1:eFa-4.0.4-32.eFa.el7.noarch (eFa4)
Not found
Is there a way to fix this? Skip-broken didn't work. Any ideas?
Update dependency mariadb error
Re: Update dependency mariadb error
Try manually removing mariadb101u-devel and update again.
you did already try
as mentioned in viewtopic.php?t=4788
yum swap -- mariadb101u-config mariadb101u-server -- mariadb102-server
Thank you! Replacing mariadb did the trick.
Thanks for the URL, it saved my bacon. After swapping mariadb the web gui broke this this error:
The following conf.php mandatory entries are missing, check and compare your conf.php with conf.php.example. - DB_PORT
I thought the package manager may have archived the config but after reading the thread I found all I had to do was "yum upgrade eFa" and I was back up and running without even losing my settings.
