daily upgrade 12.7.
arazim1284
daily upgrade 12.7.
Post by arazim1284 »
/etc/cron.daily/0yum-daily.cron:
Failed to check for updates with the following error message:
Failed to build transaction: mariadb102-server conflicts with 1:mariadb101u-server-10.1.41-1.el7.ius.x86_64
mariadb101u-common conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
mariadb102 conflicts with 1:mariadb101u-10.1.41-1.el7.ius.x86_64
mariadb101u-config conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
mariadb101u-errmsg conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
mariadb101u-libs conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
Any idea what to do with it?
Thanx
victorburgos
Re: daily upgrade 12.7.
Post by victorburgos »
Same problem here:
Installed version 1:4.0.4-13.eFa.el7
Available version 1:4.0.4-14.eFa.el7
Loaded plugins: fastestmirror
* base: mirror.its.dal.ca
* eFa4: dl7.efa-project.org
* epel: d2lzkl7pfhq30w.cloudfront.net
* extras: centos.mirror.globo.tech
* updates: mirror.dst.ca
Resolving Dependencies
--> Running transaction check
---> Package eFa.noarch 1:4.0.4-13.eFa.el7 will be updated
---> Package eFa.noarch 1:4.0.4-14.eFa.el7 will be an update
--> Processing Dependency: mariadb102-server >= 3:10.2.30-1 for package: 1:eFa-4.0.4-14.eFa.el7.noarch
---> Package mariadb102-server.x86_64 3:10.2.30-1.el7.ius will be installed
--> Processing Dependency: mariadb102-errmsg(x86-64) = 3:10.2.30-1.el7.ius for package: 3:mariadb102-server-10.2.30-1.el7.ius.x86_64
--> Processing Dependency: mariadb102-common(x86-64) = 3:10.2.30-1.el7.ius for package: 3:mariadb102-server-10.2.30-1.el7.ius.x86_64
--> Processing Dependency: mariadb-libs(x86-64) < 1:10 for package: 3:mariadb102-server-10.2.30-1.el7.ius.x86_64
--> Processing Dependency: mariadb102(x86-64) for package: 3:mariadb102-server-10.2.30-1.el7.ius.x86_64
---> Package mariadb-libs.x86_64 1:5.5.68-1.el7 will be installed
---> Package mariadb102.x86_64 3:10.2.30-1.el7.ius will be installed
--> Processing Dependency: mariadb102-libs(x86-64) = 3:10.2.30-1.el7.ius for package: 3:mariadb102-10.2.30-1.el7.ius.x86_64
---> Package mariadb102-common.x86_64 3:10.2.30-1.el7.ius will be installed
---> Package mariadb102-errmsg.x86_64 3:10.2.30-1.el7.ius will be installed
---> Package mariadb102-libs.x86_64 3:10.2.30-1.el7.ius will be installed
--> Processing Conflict: 1:mariadb101u-common-10.1.41-1.el7.ius.x86_64 conflicts mariadb-libs < 1:10.1.41-1.el7.ius
--> Processing Conflict: 1:mariadb101u-config-10.1.41-1.el7.ius.x86_64 conflicts mariadb-libs < 1:10.1.41-1.el7.ius
--> Processing Conflict: 1:mariadb101u-errmsg-10.1.41-1.el7.ius.x86_64 conflicts mariadb-libs < 1:10.1.41-1.el7.ius
--> Processing Conflict: 1:mariadb101u-libs-10.1.41-1.el7.ius.x86_64 conflicts mariadb-libs < 1:10.1.41-1.el7.ius
--> Processing Conflict: 3:mariadb102-server-10.2.30-1.el7.ius.x86_64 conflicts mariadb-server < 3:10.2.30-1.el7.ius
--> Processing Conflict: 3:mariadb102-10.2.30-1.el7.ius.x86_64 conflicts mariadb < 3:10.2.30-1.el7.ius
Error: mariadb102-server conflicts with 1:mariadb101u-server-10.1.41-1.el7.ius.x86_64
Error: mariadb101u-common conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
Error: mariadb102 conflicts with 1:mariadb101u-10.1.41-1.el7.ius.x86_64
Error: mariadb101u-config conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
Error: mariadb101u-errmsg conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
Error: mariadb101u-libs conflicts with 1:mariadb-libs-5.5.68-1.el7.x86_64
max_of_tl
Post by max_of_tl »
I was just about to ask that very same question.
ayh20
Post by ayh20 »
And here ....
Pukkeltje
Post by Pukkeltje »
Same problem here. I think the upgrade for MariaDB 10.1 to 10.2 is a major upgrade and needs an uninstall of MariaDB 10.1...
victorburgos
I found this information on this link: https://github.com/iusrepo/mariadb101u/issues/10
But I don´t feel comfortable executing them, I don´t want to brake upgradability.
Expert advise would be appreciated.
The issue is that you already have mariadb-libs (stock) installed, and they conflict with each other due to files being in the same locations. You either have to remove mariadb-libs first, or swap mariadb-libs and mariadb101u-libs in a single transaction.
yum swap mariadb-libs mariadb101u-libs
You could also use yum shell to install more packages in the same transaction.
# yum shell
> erase mariadb-libs
> install mariadb101u-libs mariadb101u-server
> run
ajmind
Post by ajmind »
# yum shell
> erase mariadb-libs
> run
Does not solve the problem on my install. :think: :?:
kikowss
Post by kikowss »
Same problem here...
r00tsh3ll
Post by r00tsh3ll »
I had the same issue too.
After digging a bit, I found an explanation about what is going on here: https://github.com/iusrepo/mariadb102/w ... ementation.
I was able to do the update with the following steps:
Install DNF
yum install dnf
Upgrade mariadb using DNF and --allowerasing:
dnf --allowerasing install mariadb102-server
Upgrade the existing inststallation db files
mysql_upgrade
Restart and enable mariadb
systemctl restart mariadb
systemctl enable mariadb
Check if there is something left to upgrade
yum upgrade
It worked for me but try it at your own risk ...
EDIT:
After the upgrade the data wasn't injected anymore in the MailWatch database. I guess some other services need a restart too so it reconnects to the DB, but in a hurry a did a reboot of the VM to restart everything, which fixed the problem.
kikowss
Post by kikowss »
It worked for me too - eFa-4.0.4 centos7.
Thank you r00tsh3ll ! :)
cobaltsupport
Post by cobaltsupport »
Many thanks - The fix also worked for me! ;)
ajmind
Post by ajmind »
I have used the swap method:
yum swap -- mariadb101u-config mariadb101u-server -- mariadb102-server
Unfortunately I had overlooked that this leads to
Jul 16 11:51:28 Erased: 1:eFa-4.0.4-13.eFa.el7.noarch
Jul 16 11:51:32 Erased: 1:mariadb101u-server-10.1.41-1.el7.ius.x86_64
Jul 16 11:51:33 Erased: 1:mariadb101u-errmsg-10.1.41-1.el7.ius.x86_64
Jul 16 11:51:33 Erased: 1:mariadb101u-10.1.41-1.el7.ius.x86_64
Jul 16 11:51:33 Erased: 1:mariadb101u-libs-10.1.41-1.el7.ius.x86_64
Jul 16 11:51:33 Erased: 1:mariadb101u-common-10.1.41-1.el7.ius.x86_64
Jul 16 11:51:33 Erased: 1:mariadb101u-config-10.1.41-1.el7.ius.x86_64
So I had to
yum install eFa
which was finally successful.
sunnyg
Post by sunnyg »
Thanks, the steps given worked for me :)
max_of_tl
Post by max_of_tl »
r00tsh3ll wrote: 15 Jul 2021 23:00
mysql_upgrade
Thanks r00tsh3ll. Your suggestions worked. The only thing I had to do differently was restart mariadb before running mysql_upgrade (otherwise it gives an error). Then reboot.
Good call man!
:clap:
eFa-4.0.4-16 should help alleviate these conflicts (hopefully).
