EFA Web GUI Not Loading
ruler202
Post by ruler202 »
I have a very strange issue with a EFA server we use.
It is fully functioning sending and passing mail, however we cannot seem to access the Web Gui.
I can telnet to the ports 80 and 443 not problem at all.
Just wondered if anyone might have any solutions or ideas where to start :)?
Many Thanks,
Steven Parsons
Been going through over forum topics similar and I cannot get to the test.php page.
But i do get this!
[efa@efamailserver ~]$ file /var/www/html/mailscanner/conf.php
/var/www/html/mailscanner/conf.php: PHP script text
barbours
Re: EFA Web GUI Not Loading
Post by barbours »
Are you on the same subnet? Could it be a DNS issue?
If you do a ps -A from a shell, do you see the httpd PID?
ruler202
Post by ruler202 »
The EFA server is on a cloud server so not local to me.
I have tried connecting to it from our office and a customer server to test the DNS issue and no luck sadly.
I have tested the the command given and can see the following HTTPD processes:
51357 ? 00:00:03 httpd
51358 ? 00:00:03 httpd
51359 ? 00:00:03 httpd
51360 ? 00:00:03 httpd
51361 ? 00:00:03 httpd
51362 ? 00:00:03 httpd
51363 ? 00:00:03 httpd
51364 ? 00:00:03 httpd
I have also had no further luck finding what could be causing it. My gut feeling currently is the firewall, would you know anyway I can check this correctly?
Many Thanks,
Steven Parsons
barbours
Post by barbours »
Couple more questions:
Also, have you tried to get to the Gui using the IP Address of the server instead of the name?
Did you enable the Lets Encrypt function on the shell menu?
I had some issues with the letsencrypt during an install and now create the letsencrypt certificates manually.
ruler202
Post by ruler202 »
Hi Barbours,
I have tried it without the domain and its still no worked sadly.
I also tested the ports and ports 80 and 443 I can telnet into which is weird!
There is SSL enabled for HTTPS but I have not applied lets encrypt.
I might have to restore from a backup as its been over a week now sadly :(.
Many Thanks,
Steven Parsons
ruler202
Post by ruler202 »
Hi Barbours,
Thank you for all your help.
I sat down this morning looking at it follow just posting and wanted to give you an update. I have been able to resolve the issue I had to re apply the HTTPS settings for Apache in option 11 on the cli menu, and it reapplied its rules and its started working!
Thank you for your help mate!
Many Thanks,
Steven Parsons
