Sender Base Routing
Re: Sender Base Routing
not sure if anyone else has tried it but it does not work for me.
has anyone else had the same experience?
Found It. this worked for me. Since Postfix is version 2.7 in EFA, the link above no longer applies.shawniverson wrote:I believe that you can do this with postfix.
http://www.3d4x.ch/swift/senderbased.html
i used what is instructed here. and it works like a charm.
http://kostja-osipov.livejournal.com/32518.html
