Sender Base Routing
curibe
Sender Base Routing
Post by curibe »
Is this feature available??
Re: Sender Base Routing
I believe that you can do this with postfix.
http://www.3d4x.ch/swift/senderbased.html
curibe
Post by curibe »
not sure if anyone else has tried it but it does not work for me.
has anyone else had the same experience?
curibe
Post by curibe »
shawniverson wrote:I believe that you can do this with postfix.
Found It. this worked for me. Since Postfix is version 2.7 in EFA, the link above no longer applies.
i used what is instructed here. and it works like a charm.
http://kostja-osipov.livejournal.com/32518.html
:dance: :clap: :ugeek: :violin: :whistle:
:text-bravo:
