Users cannot release spam
Ehlo
Post by Ehlo »
I'm aware there's another topic with the same subject, but it seems to me I've a different problem.
The problem is that the users receive the mail with the link to release the mail; but when they click on it, the message appears that the mail is being released. And then...nothing happens...
And when they click once more, they get this message:
Your message has not been released from quarantine.
Our system indicates that this message has already been released once, or the original notification message has expired. Notification messages to release spam expire after 3 days. Your message can be released again by accessing your spam quarantine.
Users cannot access the spam quarantaine, so we (admins) have to release the mail...
I did some basic checks: see log files (but I don't see anything about releasing mail), rights etc. no succes...
Can somebody help me out? Point me in the right direction?
DaN
Re: Users cannot release spam
Post by DaN »
which version do you use?
/etc/EFA-Version
Are you seeing anything in /var/log/maillog when the link is clicked?
I'm going to run some tests on my end too...want to make sure this isn't a bug from the update....
Ehlo
Post by Ehlo »
Thank you for your replies!
No, I didn't see anything in maillog when I clicked on the link...
As for the version: I guess it's 3.0.0.6, but I'm not sure...and I can't login and see (weekend... :) )
Ehlo
Post by Ehlo »
[root@EFA01 log]# cat /etc/EFA-Version
EFA-3.0.0.6
So, it's not the latest version... maybe an update would help solve this problem?
Ehlo
Post by Ehlo »
Found something in maillog!
when the user clicks the first time on the link:
Mar 2 08:29:09 EFA01 postfix/sendmail[13677]: fatal: apache(48): No recipient addresses found in message header
DaN
Post by DaN »
The releasenotes: viewtopic.php?f=8&p=2935#p2935
I don't see any related problem. Because of POODLE, GHOST and co. an update is recommended.
Ehlo wrote:Mar 2 08:29:09 EFA01 postfix/sendmail[13677]: fatal: apache(48): No recipient addresses found in message header
What we need to do is look up one of the emails that is causing this and take a look at its header. This error means that postfix is having problems relaying the message to the recipient(s) becuase it can find the recipient address for some reason.
Ehlo
Post by Ehlo »
Thank you again...
I've updated to version .7, but the problem still exists.
You were right: there is a problem with the headers.
I've attached two screenshots:
(on another server) showing adresses
not working
not working
not showing adresses.
Working
Working
How can I solve this issue?
DaN
Post by DaN »
The "Message Headers" are one click earlier, shown by "detail.php" (after the click on "[ ]").
Ehlo
Post by Ehlo »
Here you are:
X-Greylist: from auto-whitelisted by SQLgrey-1.8.0
Received: from DOMAIN (DOMAIN.DOM [IP ADRESS])
(using TLSv1 with cipher AES128-SHA (128/128 bits))
by EFA01.DUMMY (Postfix) with ESMTPS id 1D90160053
for <DUMMY TO>; Wed, 4 Mar 2015 15:14:40 +0100 (CET)
Received: from LED-SBS.LED.local ([fe80::24d2:c651:b9c2:5d50]) by
LED-SBS.LED.local ([fe80::24d2:c651:b9c2:5d50%10]) with mapi id
14.03.0224.002; Wed, 4 Mar 2015 15:14:38 +0100
To: DUMMY TO>
Subject: RE: OFFERTE MUG/MUD
Thread-Topic: OFFERTE MUG/MUD
Thread-Index: AQHQVOKctYyIgh8Nj0yyftD5ei6RN50MSdZw////N4CAABWLQP//8boAgAAQ6LA=
Date: Wed, 4 Mar 2015 14:14:38 +0000
Message-ID: <1235BB46E6AAF545BC43E7D04B2BB32324C00B32@LED-SBS.LED.local>
References: <DC975D4C23EECE40AF9DBAA3957B9AC81CD05231@LED-SBS.LED.local>
<8F91C63751B4434BBE2A21864D44D2E3E3CB5F47@DUMMY>
<8F91C63751B4434BBE2A21864D44D2E3E3CB61A3@DUMMY>
<8F91C63751B4434BBE2A21864D44D2E3E3CB6204@DUMMY>
<1235BB46E6AAF545BC43E7D04B2BB32324C007AF@LED-SBS.LED.local>
<8F91C63751B4434BBE2A21864D44D2E3E3CB8389@DUMMY>
<1235BB46E6AAF545BC43E7D04B2BB32324C00AB6@LED-SBS.LED.local>
<8F91C63751B4434BBE2A21864D44D2E3E3CB8546@DUMMY>
In-Reply-To: <8F91C63751B4434BBE2A21864D44D2E3E3CB8546@DUMMY>
Accept-Language: nl-BE, en-US
Content-Language: nl-NL
X-MS-Has-Attach: yes
X-MS-TNEF-Correlator:
x-originating-ip: [192.168.1.35]
Content-Type: multipart/related;
boundary="_004_1235BB46E6AAF545BC43E7D04B2BB32324C00B32LEDSBSLEDlocal_";
type="multipart/alternative"
MIME-Version: 1.0
This header is malformed. :?:
To: Receiver mail adress>
DaN
Post by DaN »
Just a wrong search and replace handlig?
Can you lookup the message ID and locate the message in the quarantine under the hood?
sudo view /var/spool/MailScanner/quarantine/<date>/<messagid>
We need to see the raw message to determine if this is us or the remote mailserver causing your issue.
Ehlo
Post by Ehlo »
Hope this is better. However, I have censored the message a bit (mail.server etc):
Received: from mail.server.be (mail.server.be [99.99.99.99])
by our.EFA.server (Postfix) with ESMTPS id 1D90160053
for <receiver@mail.addr>; Wed, 4 Mar 2015 15:14:40 +0100 (CET)
To: receiver <receiver@mail.addr>
<8F91C63751B4434BBE2A21864D44D2E3E3CB5F47@mail.server.nl>
<8F91C63751B4434BBE2A21864D44D2E3E3CB61A3@mail.server.nl>
<8F91C63751B4434BBE2A21864D44D2E3E3CB6204@mail.server.nl>
<8F91C63751B4434BBE2A21864D44D2E3E3CB8389@mail.server.nl>
<8F91C63751B4434BBE2A21864D44D2E3E3CB8546@mail.server.nl>
In-Reply-To: <8F91C63751B4434BBE2A21864D44D2E3E3CB8546@mail.server.nl>
MIME-Version: 1.0
--_004_1235BB46E6AAF545BC43E7D04B2BB32324C00B32LEDSBSLEDlocal_
Content-Type: multipart/alternative;
boundary="_000_1235BB46E6AAF545BC43E7D04B2BB32324C00B32LEDSBSLEDlocal_"
--_000_1235BB46E6AAF545BC43E7D04B2BB32324C00B32LEDSBSLEDlocal_
Content-Type: text/plain; charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Based on the information you have posted, I have to say the header is getting mangled during processing of these emails.
To troubleshoot this further and isolate the issue, please PM me. I am going to need a sample message file from your quarantine that is intact and unaltered.
Ehlo
Post by Ehlo »
I have sent you a PM, but it's stuck in my outbox.
Seems I cannot attach the file you requested to that message. Can I send it to you otherwise?
