signature
Posted: 25 Nov 2014 07:21
by Ravikant144
Any One can suggest me how can i remove Signature
This message has been scanned for viruses and dangerous content by
E.F.A. Project, and is believed to be clean.
Re: signature
Posted: 28 Nov 2014 16:34
You can disable the signature using EFA-Configure.
Re: signature
Posted: 18 Mar 2015 12:46
(for completeness, from
viewtopic.php?f=14&t=684&p=1871&hilit=d ... ture#p1871 )
Use efa-configure --> Spam Settings --> Non-Spam Settings
You can disable signatures here.
Re: signature
Posted: 19 Jan 2017 11:38
looks like this is a complete ON/OFF settings, I am however looking to only disable adding signatures to OUTGOING emails.
I looked around and it seems this rule could be the solution: sig.html.rules + sig.txt.rules
this is what the first one looked like originally:
To: default /etc/MailScanner/reports/en/inline.sig.out.html
To: *@mydomain1.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.html
so I tried modifying it:
but a MailScanner --lint warned me:
Could not read file no at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2856
Syntax error in line 4 of ruleset file /etc/MailScanner/rules/sig.html.rules at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2803
Any ideas how to do this?
Re: signature
Posted: 31 Jan 2017 13:10
Is this possible? Anyone? I suspect the outgoing signature messes up my DKIM signing :-/
Re: signature
Posted: 03 Feb 2017 10:41
Try this, drop the first line:
Re: signature
Posted: 07 Feb 2017 09:17
Didn't seem to work out in the sense that mails still get signed going in and out so now I am determined to stop signing them altogether in order to sort out my DKIM headers.
I went to efa-configure --> Spam Settings --> Non-Spam Settings and disabled signing non-spam emails.
Inside /etc/MailScanner/MailScanner.conf
Inline HTML Signature = %rules-dir%/sig.html.rules
Inline Text Signature = %rules-dir%/sig.text.rules
Sign Messages Already Processed = no
Sign Clean Messages = No
cat /etc/MailScanner/rules/sig.text.rules
To: default /etc/MailScanner/reports/en/inline.sig.out.txt
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.txt
/etc/MailScanner/reports/en/inline.sig.out.txt has content
cat /etc/MailScanner/rules/sig.html.rules
To: *@prehcm.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@prehcmservices.de /etc/MailScanner/reports/en/inline.sig.in.html
/etc/MailScanner/reports/en/inline.sig.out.html has content
Re: signature
Posted: 07 Feb 2017 11:22
I would be curious if this might work:
To: default no
Re: signature
Posted: 08 Feb 2017 13:07
sorry to say but deleting the "default" line then /etc/init.MaiLScanner reload doesn't change anything, I still get footers added for outgoing emails.
Changing the default to no gives the same syntax error as I first reported.
Re: signature
Posted: 08 Feb 2017 18:24
What if instead of no you put /dev/null ?
Re: signature
Posted: 09 Feb 2017 10:40
OK, this is officially driving me insane. I can't test /dev/null "live" I might give it a try over the weekend.
BUT I just set this up in MailScanner.conf
RESTARTED MailScanner and guess what? I still get a footer added to my outgoing messages:
our in-house Email Filtering Appliance, and is believed to be clean.
I really just want to disable any and all footers, in and outgoing. Any advice on how to do that?
Re: signature
Posted: 09 Feb 2017 11:08
Look at Spam Actions and Non Spam Actions and remove the "custom" entry for each.
Re: signature
Posted: 09 Feb 2017 11:26
ah, thanks for clarifying.
- is that all that the custom action does?
- are there any drawbacks to simply doing this inside the conf file vs. the EFA interface?
Re: signature
Posted: 05 Mar 2018 04:43
by froman
in effect, when the E.F.A puts the footer, the dkim signature gets invalid.
I'm trying to disable the signature only on the outgoing clean mails, but it doesn't work, the only way I found is disable the clean message signature, but this is for incoming and outgoing emails.
