signature
Ravikant144
signature
Post by Ravikant144 »
Any One can suggest me how can i remove Signature
This message has been scanned for viruses and dangerous content by
E.F.A. Project, and is believed to be clean.
Re: signature
You can disable the signature using EFA-Configure.
Re: signature
(for completeness, from
viewtopic.php?f=14&t=684&p=1871&hilit=d ... ture#p1871 )
Use efa-configure --> Spam Settings --> Non-Spam Settings
You can disable signatures here.
ovizii
Re: signature
Post by ovizii »
looks like this is a complete ON/OFF settings, I am however looking to only disable adding signatures to OUTGOING emails.
I looked around and it seems this rule could be the solution: sig.html.rules + sig.txt.rules
this is what the first one looked like originally:
To: default /etc/MailScanner/reports/en/inline.sig.out.html
To: *@mydomain1.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.html
so I tried modifying it:
but a MailScanner --lint warned me:
Could not read file no at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2856
Syntax error in line 4 of ruleset file /etc/MailScanner/rules/sig.html.rules at /usr/share/MailScanner/perl/MailScanner/Config.pm line 2803
Any ideas how to do this?
ovizii
Re: signature
Post by ovizii »
Is this possible? Anyone? I suspect the outgoing signature messes up my DKIM signing :-/
Re: signature
Try this, drop the first line:
ovizii
Re: signature
Post by ovizii »
Didn't seem to work out in the sense that mails still get signed going in and out so now I am determined to stop signing them altogether in order to sort out my DKIM headers.
I went to efa-configure --> Spam Settings --> Non-Spam Settings and disabled signing non-spam emails.
Inside /etc/MailScanner/MailScanner.conf
Inline HTML Signature = %rules-dir%/sig.html.rules
Inline Text Signature = %rules-dir%/sig.text.rules
Sign Messages Already Processed = no
Sign Clean Messages = No
cat /etc/MailScanner/rules/sig.text.rules
To: default /etc/MailScanner/reports/en/inline.sig.out.txt
To: *@mydomain2.de /etc/MailScanner/reports/en/inline.sig.in.txt
/etc/MailScanner/reports/en/inline.sig.out.txt has content
cat /etc/MailScanner/rules/sig.html.rules
To: *@prehcm.de /etc/MailScanner/reports/en/inline.sig.in.html
To: *@prehcmservices.de /etc/MailScanner/reports/en/inline.sig.in.html
/etc/MailScanner/reports/en/inline.sig.out.html has content
Re: signature
I would be curious if this might work:
To: default no
ovizii
Re: signature
Post by ovizii »
sorry to say but deleting the "default" line then /etc/init.MaiLScanner reload doesn't change anything, I still get footers added for outgoing emails.
Changing the default to no gives the same syntax error as I first reported.
Re: signature
What if instead of no you put /dev/null ?
ovizii
Re: signature
Post by ovizii »
OK, this is officially driving me insane. I can't test /dev/null "live" I might give it a try over the weekend.
BUT I just set this up in MailScanner.conf
RESTARTED MailScanner and guess what? I still get a footer added to my outgoing messages:
our in-house Email Filtering Appliance, and is believed to be clean.
I really just want to disable any and all footers, in and outgoing. Any advice on how to do that?
Re: signature
Look at Spam Actions and Non Spam Actions and remove the "custom" entry for each.
ovizii
Re: signature
Post by ovizii »
ah, thanks for clarifying.
- is that all that the custom action does?
- are there any drawbacks to simply doing this inside the conf file vs. the EFA interface?
froman
Re: signature
Post by froman »
in effect, when the E.F.A puts the footer, the dkim signature gets invalid.
I'm trying to disable the signature only on the outgoing clean mails, but it doesn't work, the only way I found is disable the clean message signature, but this is for incoming and outgoing emails.
