Hi Everyone,
I am trying to update my EFA on a OpenVZ virtualmachine but it's not working. Can you guys help me:
$ sudo /usr/local/sbin/EFA-Update -update
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.0.6
Loaded plugins: fastestmirror
Setting up Update Process
* base: mirror.es.its.nyu.edu
* extras: mirror.es.its.nyu.edu
* rpmforge: repoforge.mirror.constant.com
* updates: centos.mirror.constant.com
No Packages marked for Update
grep: /boot/grub/menu.lst: No such file or directory
Your system has an updated kernel, but you are not running
on the latest kernel. Please restart your system and run
EFA-Update after restart.
Update EFA on OpenVZ
Re: Update EFA on OpenVZ
I have not tried EFA on OpenVZ....This looks like it is failing trying to query grub. Are you using grub?
Thanks for your reaction! Not using grub. I just managed to update EFA after I removed the kernel check in update script.
