Hi All,
Sorry with the newb question, but how to I go about accessing MailScanner web interface? I thought it was just: hostname.domain.name/mailscanner But I guess not? I try that and the page never loads. Do I need to do additional configuration?
Reading of the FAQs I know it may be a touchy subject, but, would I be able to get Baruwa 2.x configured and working with E.F.A 3.0.0.4 as the front-end?
How to access MailScanner
Re: How to access MailScanner
Just connect to the IP or hostname of your EFA box.
EFA 3.x has nothing to do with baruwa anymore, we switched over to mailwatch as the frontend.
Baruwa uses a completely different setup which has changed so much in the past that it was a bit hard to maintain so mailwatch is the gui we use and keep using on this project.
I tried both just the IP address, and also tried just the hostname. The pages just keep timing out.
I am able to get into Webmin no problem using IP:10000
Can I try restarting the MailScanner service from shell?
How can I verify that the service is running and configured properly?
if you login with ssh go top the option for system shell.
Then do a
you should see something like:
meaning that apache is running and serving the mailwatch interface.
Then do a
ps -ef f
apache 1584 1553 0 Aug17 ? S 0:01 \_ /usr/sbin/httpd
apache 1585 1553 0 Aug17 ? S 0:01 \_ /usr/sbin/httpd
apache 1586 1553 0 Aug17 ? S 0:00 \_ /usr/sbin/httpd
apache 1587 1553 0 Aug17 ? S 0:03 \_ /usr/sbin/httpd
apache 1588 1553 0 Aug17 ? S 0:01 \_ /usr/sbin/httpd
apache 1589 1553 0 Aug17 ? S 0:01 \_ /usr/sbin/httpd
apache 1590 1553 0 Aug17 ? S 0:00 \_ /usr/sbin/httpd
apache 1591 1553 0 Aug17 ? S 0:02 \_ /usr/sbin/httpd
I ran:
I see the apache services:
ps -ef f
apache 1678 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1679 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1680 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1681 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1682 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1683 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1684 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
apache 1686 1657 0 09:35 ? S 0:00 \_ /usr/sbin/httpd
When I SSH into the system, from the Configuration program, in option 11, I have chosen to enable port 443 for secure access, and chose to forward all port 80 traffic to 443 also.
I tried this also, but got the same results:
https://IPaddress:443
**FIXED**
I was able to resolve the issue, thanks to a previous post of yours in the bug section of the forum entitled "EFA webgui (MailWatch) change to HTTPS"
Basically after checking the iptables, there was no entry to accept port 443. So I followed the instructions:
And then
And viola! I am able to access MailScanner web interface now by going to: https://IPofEFAserver
-A INPUT -m state --state NEW -m tcp -p tcp --dport 443 -j ACCEPT
sudo service iptables reload
