3.0.5 Version
Posted: 01 Aug 2014 13:34
by buzzzo
When 3.0.5 will be released ?
Re: 3.0.5 Version
Posted: 01 Aug 2014 13:42
by darky83
Soon,
We have frozen new functions and are testing the build and upgrade path.
Re: 3.0.5 Version
Posted: 01 Aug 2014 14:26
by buzzzo
Is is safe to get the scripts and use it form "diy" upgrade to 3.0.5 ?
Can i assume the "frozen" means that no other features will be addes ?
Thx
Re: 3.0.5 Version
Posted: 01 Aug 2014 15:28
by darky83
There are some issues after our first test upgrades (due to new mailwatch version..) so I would not use it untill the final is released.
Re: 3.0.5 Version
Posted: 01 Aug 2014 17:00
by buzzzo
Well ...and seems that on the git repo some files are not in the place where is supposed to be.
wgetting from update script gives 404 error.
thx
Re: 3.0.5 Version
Posted: 02 Aug 2014 17:22
That is correct and expected. We haven't spawned the official 3.0.0.5 branch yet. Update scripts for 3.0.0.5 will not function without modification as they are currently living in the master branch.
Re: 3.0.5 Version
Posted: 24 Aug 2014 19:19
