When 3.0.5 will be released ?
3.0.5 Version
Re: 3.0.5 Version
Soon,
We have frozen new functions and are testing the build and upgrade path.
Re: 3.0.5 Version
Is is safe to get the scripts and use it form "diy" upgrade to 3.0.5 ?
Can i assume the "frozen" means that no other features will be addes ?
Thx
Thx
Re: 3.0.5 Version
There are some issues after our first test upgrades (due to new mailwatch version..) so I would not use it untill the final is released.
Re: 3.0.5 Version
Well ...and seems that on the git repo some files are not in the place where is supposed to be.
wgetting from update script gives 404 error.
thx
thx
Re: 3.0.5 Version
That is correct and expected. We haven't spawned the official 3.0.0.5 branch yet. Update scripts for 3.0.0.5 will not function without modification as they are currently living in the master branch.
Re: 3.0.5 Version
It's out!!!!!!
