Webmin packages update
menny
Post by menny »
Do i need to update Webmin or webmin's packages?
Can they break EFA?
darky83
Site Admin
Re: Webmin packages update
Post by darky83 »
This will be upgrade in the latest efa-update (3.0.0.5)
No need for manual updates.
menny
Post by menny »
when will the update be released?
We are getting close. We are currently testing the 3.0.0.5 and committing final fixes prior to release.
We are taking a little more time to make this update as smooth as possible for everybody.
Hopefully in the next coming weeks it will be ready.
menny
Post by menny »
Thanks again.
do you have any idea what can cause large email (1mb and above to get stuck in queue)
and small file go through with no problems?
some post that describe the issue:
/viewtopic.php?f=13&t=578
/viewtopic.php?f=13&t=601
for now i returned working with ESVA 2.
will appreciate your help.
What's attached to the email, out of curiosity?
menny
Post by menny »
i have tried many different attachments like mp3, pdf, doc, xls, txt and others.
email with large files just wont go through.
I see. Sending inbound or outbound?
I am going to test this on my system and see what happens...
Here's what I get when I send a large file through my system...
Jul 17 21:49:15 efa MailScanner[8413]: Message 633AE80766.ACE6F from xxx.xxx.xxx.xxx (root@rushville.k12.in.us) to gmail.com is too big for spam checks (6045573 > 1024000 bytes)
Jul 17 21:49:15 efa MailScanner[8413]: Requeue: 633AE80766.ACE6F to 8855E8092C
Jul 17 21:49:15 efa MailScanner[8413]: Uninfected: Delivered 1 messages
Jul 17 21:49:15 efa postfix/qmgr[8392]: 8855E8092C: from=<root@rushville.k12.in.us>, size=6044931, nrcpt=1 (queue active)
Jul 17 21:49:15 efa MailScanner[8413]: Logging message 633AE80766.ACE6F to SQL
Jul 17 21:49:18 efa postfix/smtp[8592]: 8855E8092C: to=<shawniverson@gmail.com>, relay=gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=10, delays=7.5/0.03/0.66/2.2, dsn=2.0.0, status=sent (250 2.0.0 OK 1405648158 j5si467470igx.37 - gsmtp)
Jul 17 21:49:18 efa postfix/qmgr[8392]: 8855E8092C: removed
What does your maillog show when you send a large file?
