Next Major Release of EFA
For EFA version 4x, I feel like there is a need to change some things...
1) Completely RPM-based
I think that efa-update and yum update methods cause issues for existing users. Those that are not familiar with EFA who try to update EFA with yum risk breaking their systems...
Wouldn't it be nice to just yum update at any time you need and know you are running an up-to-date system? EFA could have an RPM repo of its own for all packages...
Thoughts?
2) A GUI based configuration tool.
The CLI tool is nice, but wouldn't it be nice to have a GUI tool too?
MSRE is coming in mailwatch, but a comprehensive GUI tool would greatly enhance EFA...
Thoughts?
3) Better GUI
EMFA screenshots... http://blog.cycomptec.com/coming-soon-e ... -security/
Let's make a GUI that rivals this one!
Thoughts?
darky83
Site Admin
Re: Next Major Release of EFA
Post by darky83 »
1) Yep been thinking about a way to just create EFA RPM's for all mayor items.
I got the hosting already setup to facilitate this so now we only have the 'small 'task to create rpm's from all items....... :techie-hiding:
2/3) Eventually I would like to have everyting in a web based GUI but this requires some more programming skills (and in what language, php,python etc.. I prefer python but I'm not that good at it :)
ryan20208
Post by ryan20208 »
Before thinking about new major releases the we all together should find an solution for the
Bad phishing site update script problem --> Unable to retrieve http://cdn.mailscanner.info.
Any IDEA's
Thank you.
ryan20208
Post by ryan20208 »
OK mailscanner.info is back now !!!! thank you ...
buzzzo
Post by buzzzo »
Hi all
Before re-write from scratch a webgui for EFA you could take a look to mine in progress.
Darky&Shawn: If you get me your static ip address i will open an access on my dev box so you will see my work.
After your comments we could decide if it could be the right road for official EFA.
Thx
ryan20208
Post by ryan20208 »
Cool --> but currently for me the non working update_bad_phishing_sites script will stop all thinking about a working GUI ...
[root@ilx914 sbin]# ./update_bad_phishing_sites
Reading status from /var/spool/MailScanner/quarantine/phishingupdate/status
Checking that /var/spool/MailScanner/quarantine/phishingupdate/cache/2014-230 exists... no - resetting..... ok
Checking that /var/spool/MailScanner/quarantine/phishingupdate/cache/-1.0 exists... ok
I am working with: Current: 2014-230 - 5 and Status: -1 - 0
This is base update
Unable to retrieve http://cdn.mailscanner.info/.2014-230 :500 Can't connect to cdn.mailscanner.info:80 (Bad hostname 'cdn.mailscanner.info')
Update required
Retrieving http://cdn.mailscanner.info/2014-230.1
Failed to retrieve http://cdn.mailscanner.info/2014-230.1 at ./update_bad_phishing_sites line 198.
Retrieving http://cdn.mailscanner.info/2014-230.2
Failed to retrieve http://cdn.mailscanner.info/2014-230.2 at ./update_bad_phishing_sites line 198.
Retrieving http://cdn.mailscanner.info/2014-230.3
Failed to retrieve http://cdn.mailscanner.info/2014-230.3 at ./update_bad_phishing_sites line 198.
Retrieving http://cdn.mailscanner.info/2014-230.4
Failed to retrieve http://cdn.mailscanner.info/2014-230.4 at ./update_bad_phishing_sites line 198.
Retrieving http://cdn.mailscanner.info/2014-230.5
Failed to retrieve http://cdn.mailscanner.info/2014-230.5 at ./update_bad_phishing_sites line 198.
Unable to open base file (/var/spool/MailScanner/quarantine/phishingupdate/cache//2014-230)
buzzzo
Post by buzzzo »
Ryan this thread is for future works on EFA.
Note that:
1) phishing update is related to mailscanner not with efa: plz check mailscanner lists: they already suggested a fix
2) i already post on efa forums a solution (same fix as 1)
So plz don't hijack threads and read ALL threads.
darky83
Site Admin
Post by darky83 »
Buzzo I send you a pm with one of my ip's
For my info, in what language did you wrote yours? (php?)
buzzzo
Post by buzzzo »
Hi Darky.
The web gui is all coded in php , just like mailwatch and msre.
I've started from msre, so the css are based on it.
You will find the layout similar to mailwatch (yes ... not a big thing but is a start ..).
Some script are written in perl (mainly script launched from the webgui to commit the conf in postfix and other daemons conf file).
ASAP i will open access for u.
rickb813
Post by rickb813 »
Hello Shawn,
I updated my ClamAV doing just this: "Those that are not familiar with EFA who try to update EFA with yum risk breaking their systems..."
(Because the scanner log showed that I needed to)
Clam is still stopping the Viruses but in MailWatch>Status, the tagged Virus emails are "other" and virus counts are not being changed as they were.
IS there a thread I SHOULD have followed and a way back to fix this?
:shifty:
Thanks in advance,
RB
