3.0.0.4 update before bugs found
Posted: 03 Jun 2014 20:18
We had updated to 3.0.0.4 before the bugs were found with the update, everything seems to be working just fine with the exception of daily quarantine reports. Should we run fix script now anyway or suggestions? Also, is it suggested to update webmin to 1.690 now? Also, would it be possible to get the add new user at the top of the user list instead the bottom? Thanks in advance!
