3.0.0.4 update before bugs found
We had updated to 3.0.0.4 before the bugs were found with the update, everything seems to be working just fine with the exception of daily quarantine reports. Should we run fix script now anyway or suggestions? Also, is it suggested to update webmin to 1.690 now? Also, would it be possible to get the add new user at the top of the user list instead the bottom? Thanks in advance!
Re: 3.0.0.4 update before bugs found
Yes, go ahead and run the fix script.
Yes, you can update Webmin.
Are you referring to the Mailwatch user list? If so, we may need to submit a feature request to the Mailwatch devs for that one...
