Release message link results in message id syntax error
Egor
Post by Egor »
My EFAMail is script installed (on my own CentOS fresh install using the kickstart script(s) - http://efa-project.org/documentation/building_efa/). All appeared to go well and almost everything works as expected and we've filtered ~25,000 messages in the past month. For the few that are HAM but marked SPAM, when the users attempt to release the messages, they are greeted with "Error in id syntax at /var/www/cgi-bin/release-msg.cgi line 95"
The regex is : if ($id =~ /^[A-F0-9]{10}\.[A-F0-9]{5}|[A-F0-9]{11}\.[A-F0-9]{5}$/){
My URL string is
{myURL}/cgi-bin/release-msg.cgi?datenumber=20140528&id=66D96314B.AF34C&token=1accf0cd77aa7777a8aa424dbbb3bde2
I may be reading that incorrectly, but I believe the first part of the ID (66D) doesn't match the regex - I'm not as good as I think with regex. The information I found searching about release-msg.cgi did not turn up much and nothing like what I am experiencing.
darky83
Site Admin
Re: Release message link results in message id syntax error
Post by darky83 »
You are probbably running an older version of EFA
We fixed this issue in 3.0.0.1 so you should upgrade to this.
(just run the EFA-Update command from the CLI)
See the code on github https://github.com/E-F-A/v3/blob/master ... se-msg.cgi
The regex will most likely be different than yours, meaning you are on a older version.
Egor
Post by Egor »
A diff between the two files shows the only difference being the db_pass line. Both show the same version "EFA release spam message script version 20140105"
Running EFA-Update shows :
# EFA-Update -check
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are already running version EFA-3.0.0.4, no update needed
I used wget to pull the raw file from github, modified the db_pass line and still have the same error.
I don't think my id (66D96314B.AF34C) matches the regex. What generates the message id?
You are right, the regex doesn't match. The first part of your ID is 9 characters long?
Postfix changed the id scheme in a recent version. What version of postfix are you running?
Egor
Post by Egor »
We are running : postfix-2.6.6-6.el6_5.x86_64 from CentOS release 6.5 (Final)
I updated the regex to allow for 9 chars and it worked. Time to learn basic perl regex :)
darky83
Site Admin
Post by darky83 »
Added 9 character ID support to 3.0.0.5 update.
Mr. Happy
Post by Mr. Happy »
I got this message since an update a few days ago when releasing a quarantined mail...
Software error:
Error in id syntax at /var/www/cgi-bin/release-msg.cgi line 105.
For help, please send mail to the webmaster (root@localhost), giving this error message and the time and date of the error.
Update:
weird, reboot seems te have solved the problem... :roll:
