Email Quarantine Emails
Posted: 08 May 2014 07:46
by sharktech
Morning All
I have built my second version of EFA but this version doesn't email out when an email has been blocked. Is this something i need to turn on?
Just checked and the footers arent being applied either
Re: Email Quarantine Emails
Posted: 08 May 2014 15:15
by sharktech
Ran the fixes for update on 3.0.0.4 and its still not fixed this issue. my other box is on 3.0.0.4 and that one works as it should
Cheers
Posted: 08 May 2014 22:59
by Socal_Steve
Can you manually run the quarentine report? should look like below:
[root@admin]# sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
 === Generating report for user@email.com type=U
 ==== Recipient e-mail address is user@email.com
 ==== Building list for user@email.com
 ==== Found 158 quarantined e-mails
==== Sent e-mail to user@email.com
If your looking for the notifications that send a message every time a spam message is received check in your: /etc/MailScanner/MailScanner.conf
Spam Actions = store notify
Posted: 09 May 2014 08:42
by sharktech
Cheers for that
Currently it was set to Spam Actions = store custom(spam)
Changed to Spam Actions = store custom(spam)
Posted: 09 May 2014 09:38
by sharktech
Still no joy im afraid, this was a fresh install then upgraded using EFA-Update.
I've built a new one and turned auto update off for now, is there any chance that the ovf could be updated to v4?
Posted: 09 May 2014 09:41
by sharktech
On a side note, i have changed the default score for spam to 6 and thats not taking effect either even after a reboot
Posted: 11 May 2014 15:39
http://rcstech.rushville.k12.in.us/E.F. ... VMware.zip
Will notify webmaster (darky83) to see if he can update on main website.
Posted: 12 May 2014 08:50
by sharktech
Cheers for that will try it out and let you know.
Posted: 03 Jun 2014 16:07
by sharktech
Had to build another box for forgo to use the 3.0.0.4 image, updated to 3.0.0.4 and ran the script to fix the update issues and everything is working fine, apart from the notifications in mailscanner.conf its set to "Spam Actions = store custom(spam)"
Is there anything i can give you to help me find out why its not sending them out
Cheers
Posted: 03 Jun 2014 22:14
Yep. PM me and I'll see what I can do to help.
Posted: 11 Jun 2014 09:23
by sharktech
Shawniverson
Looks like i found out why it wasnt working, i changed back the report templates to default and they are being sent out now, is there no chance i can customise the reports as people don't even bother to read it as it looks to complicated (according to them) and then complains when they dont get the email.
Cheers
