Email Quarantine Emails
sharktech
Post by sharktech »
Morning All
I have built my second version of EFA but this version doesn't email out when an email has been blocked. Is this something i need to turn on?
Just checked and the footers arent being applied either
sharktech
Re: Email Quarantine Emails
Post by sharktech »
Ran the fixes for update on 3.0.0.4 and its still not fixed this issue. my other box is on 3.0.0.4 and that one works as it should
Cheers
Socal_Steve
Post by Socal_Steve »
Can you manually run the quarentine report? should look like below:
[root@admin]# sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
 === Generating report for user@email.com type=U
 ==== Recipient e-mail address is user@email.com
 ==== Building list for user@email.com
 ==== Found 158 quarantined e-mails
==== Sent e-mail to user@email.com
If your looking for the notifications that send a message every time a spam message is received check in your: /etc/MailScanner/MailScanner.conf
Spam Actions = store notify
sharktech
Post by sharktech »
Cheers for that
Currently it was set to Spam Actions = store custom(spam)
Changed to Spam Actions = store custom(spam)
sharktech
Post by sharktech »
Still no joy im afraid, this was a fresh install then upgraded using EFA-Update.
I've built a new one and turned auto update off for now, is there any chance that the ovf could be updated to v4?
sharktech
Post by sharktech »
On a side note, i have changed the default score for spam to 6 and thats not taking effect either even after a reboot
http://rcstech.rushville.k12.in.us/E.F. ... VMware.zip
Will notify webmaster (darky83) to see if he can update on main website.
sharktech
Post by sharktech »
Cheers for that will try it out and let you know.
sharktech
Post by sharktech »
Had to build another box for forgo to use the 3.0.0.4 image, updated to 3.0.0.4 and ran the script to fix the update issues and everything is working fine, apart from the notifications in mailscanner.conf its set to "Spam Actions = store custom(spam)"
Is there anything i can give you to help me find out why its not sending them out
Cheers
Yep. PM me and I'll see what I can do to help.
sharktech
Post by sharktech »
Shawniverson
Looks like i found out why it wasnt working, i changed back the report templates to default and they are being sent out now, is there no chance i can customise the reports as people don't even bother to read it as it looks to complicated (according to them) and then complains when they dont get the email.
Cheers
