3.0.0.4 Update Problems and Guidance
Fixes to help with updating to 3.0.0.4 have been backported.
https://github.com/E-F-A/v3/commit/99ce ... b83171b6f0
https://github.com/E-F-A/v3/commit/c0f5 ... 0f107ecff6
If you have already updated to version 3.0.0.4, please run the attached file to ensure proper functioning of your EFA...
update-3.0.0.4-fix.sh.zip
(2.09 KiB) Downloaded 1041 times
dajones70
Re: 3.0.0.4 Update Problems and Guidance
Post by dajones70 »
I had a couple of bugs in this script. Line 48 had an extra "fi" and the empty functions "update-3.0.0.2()" and "update-3.0.0.1()" caused errors.
I deleted lines 48 and 148-165 and it worked. The empty functions could have an echo added to them to make them valid functions.
This fixed the 3.0.0.3 bug where the "EFA-Configure" command didn't bring up the menu and just exited back to the prompt.
mshanley
Post by mshanley »
how about some instructions on how to run this?
Errors fixed. Also converted from dos to unix file format.
Instructions...
wget -O ./update-3.0.0.4-fix.sh.zip http://forum.efa-project.org/download/file.php?id=22
unzip  ./update-3.0.0.4-fix.sh.zip
chmod u+x ./update-3.0.0.4-fix.sh
sudo ./update-3.0.0.4-fix.sh
mshanley
Post by mshanley »
this works,
Thank You!
now I have the EFA Configure Menu back and im running 3.0.0.4.
Just noticed....some of you that may be using open-vm-tools...
Make sure you have a real vmtoolsd init script (and that it is not 0 bytes in size)
sudo wget -O /etc/init.d/vmtoolsd https://raw.githubusercontent.com/E-F-A/v3/3.0.0.4/build/EFA/vmtoolsd.init --no-check-certificate
sharktech
Post by sharktech »
Ran EFA-Update to go form fresh install to v3.0.0.4 ran the bash script and that worked fine, i then read the vmtools bit and tried to download it but i keep getting SSL error "cert common name www.github.com doesnt match requested hostname raw.githubusercontent.com
If i run with the --no-check-certificate i get error 404
When i did the upgrade using efa-update i did notice this aswell
Cheers
double check your syntax, the above command with --no-check-certificate is working for me.
apoangel
Post by apoangel »
Hi all,
I have a little problem.
When i try to do :
I have the error :
sudo: unable to execute ./update-3.0.0.4-fix.sh: Permission denied
I'm in the tmp directory
If i try : sudo sh /tmp/update-3.0.0.4-fix.sh/update-3.0.0.4-fix.sh
I have the error : /tmp/update-3.0.0.4-fix.sh/update-3.0.0.4-fix.sh: line 86: `update-3.0.0.4': not a valid identifier
Try running the script somewhere else besides /tmp :D
mintra
Post by mintra »
After 3.0.0.4 update issues I stopped using efa for my system as it all got too difficult, I was testing it on my domain and if I had been using it for clients this would have caused a lot of ear ache.
Anyway I find that one of my clients has from their own volition chosen to use efa so I want to have another go at solving the 3.0.0.4 update issue.
I have a snapshot of the system before the last aborted attempt so I feel I should revert to that first run the update, and then run the script. (That is the script which has a fix on it).
However when I try
wget: unable to resolve host address âforum.efa-project.orgâ
I can not ping forum.efa-project.org
Is the script listed at the top of the page still wrong?
Any help would be most welcome.
mintra
Post by mintra »
Sorry just being daft the DNS service does not seem to be running right on the efa server.
