I have having problems when I blacklist an e-mail address. I want to blacklist the address to the whole domain
I enter the domain I want to be blacklisted in the From: and leave it blank before and after @ in the To: section. This doesn't work.
I have also tried using default after the @ in the To: section - no luck
I have tried our domain name after the @ in the To: section - no luck.
All the migrated domains whitelisted and blacklisted from ESVA are working.
Blackilisting
Re: Blackilisting
To: default
The word default is required in the to: field for this to work.
Also, restart mailscanner for the change to take effect immediately
To: default
Re: Blackilisting
Many thanks...
Does this mean the blacklist entry only becomes recognised after a mailscanner restart?
Re: Blackilisting
It means that mailscanner periodically reload blacklist/whitelist from db(mysql).
In order to have new entries applied immediately you need to restart mailscanner.
