OPEN SSL Vornablilities
Posted: 08 Apr 2014 15:15
Guys,
looking at EFA it looks to be Vornable to OpenSSL.
you can test by going here:
http://filippo.io/Heartbleed
I will need to do apt-get update & apt-get upgrade.
will doing this commands upgrade EFA in some way??
or should i upgrade using your manual process.
