OPEN SSL Vornablilities
curibe
Post by curibe »
Guys,
looking at EFA it looks to be Vornable to OpenSSL.
you can test by going here:
http://filippo.io/Heartbleed
I will need to do apt-get update & apt-get upgrade.
will doing this commands upgrade EFA in some way??
or should i upgrade using your manual process.
curibe
Re: OPEN SSL Vornablilities
Post by curibe »
My opologies as the commands are for ubuntu :)
i guess i can just update openssl.
# yum update openssl
let me know if i can have your blessing. i need to make sure i don't break anything from EFA.
Yes, go for it. We will be doing the same on the next EFA update
Make sure you are on the following version of openssl:
1.0.1e-16.el6_5.7
