U4GM - Helldivers 2 Early Game Tips for Beginners
Bugs in eFa 5
FrostWolf
Post by FrostWolf »
Starting out in Helldivers 2 can feel overwhelming, especially with the amount of chaos happening on the battlefield. Whether you’re playing solo or with a squad, the early game is all about learning the basics, building good habits, and making sure you’re properly equipped for the challenges ahead. Here are some beginner-friendly tips that can help you get started.
1. Master the Basics of Movement and Shooting
One of the first things you’ll notice is that Helldivers 2 doesn’t forgive sloppy movement. Staying mobile is key, as enemies will swarm you quickly if you stand still for too long. Practice diving and rolling to avoid enemy fire, and make sure you’re comfortable switching between primary weapons, sidearms, and grenades on the fly.
2. Use Stratagems Wisely
Stratagems are game-changers, but they require precision. Dropping an airstrike or turret in the wrong place can hurt your own squad just as easily as it can take out enemies. In the early game, stick with simple, versatile options like resupply drops and automated turrets until you’re more confident with the more advanced choices.
3. Don’t Hoard Resources
Resources can feel limited early on, but you’ll progress faster by actually using what you collect. Don’t be afraid to call in resupply packs or deploy defensive tools when needed. Later, as you gain more experience, you’ll naturally become more efficient with your resource use.
4. Learn Enemy Behavior
Each faction in Helldivers 2 has unique attack patterns. Bugs swarm in numbers, while Automatons rely on firepower and positioning. Paying attention to these behaviors will help you survive longer and choose the right strategy for each mission.
5. Take Advantage of the Helldivers 2 Items Shop
The Helldivers 2 items shop provides useful gear and customization options that can make your early missions easier. You don’t need to unlock everything at once—focus on the items that improve survivability, such as better armor and reliable weapons. Over time, you’ll find what fits your playstyle best.
6. Save and Spend Super Credits Smartly
You’ll occasionally earn or choose to buy Helldivers 2 super credits, which are valuable for unlocking premium gear. Beginners should avoid spending them on purely cosmetic items too early. Instead, prioritize functional upgrades that make a real difference in battle.
7. Play With a Squad Whenever Possible
While the game can be played solo, Helldivers 2 shines in co-op. Squad play not only makes missions easier but also helps you learn from more experienced players. Good communication, even with random teammates, can turn a chaotic mission into a smooth success.
8. Practice Safe Extraction
Getting through the mission is only half the job—extraction is often where things go wrong. Always prepare defenses before calling the shuttle, and position your squad strategically. A successful extraction means all your efforts won’t go to waste.
9. Stay Updated With Reliable Sources
The game continues to evolve, and patches can bring new balance changes or items. Following communities, guides, and platforms like U4GM can help you stay ahead with useful strategies and updates.
The early game in Helldivers 2 is all about learning fundamentals, surviving the chaos, and gradually building up your arsenal. By focusing on smart resource use, understanding enemies, and taking advantage of tools like the Helldivers 2 items shop, you’ll find yourself progressing more smoothly. And if you ever decide to buy Helldivers 2 super credits, make sure you’re spending them on upgrades that truly benefit your gameplay.
