This is something I've noticed recently, that not all incoming messages are scanned. For example, see the following screenshot:
You can see that all these are very spammy messages, but one has a score of 0. Searching through the maillog for that message id shows me the following:
One of the message IDs that was properly marked shows the following:Message 4WT4vZ0qJgzMy28n from 67.219.246.152 (www-data@kamtopiaero.shop) to XXX.com is not spam, SpamAssassin (not cached, timed out)
So, spamassassin is timing out somewhere (RBL checks maybe?) and then giving a default score of 0.Jul 24 03:43:34 efa4 MailScanner[2188]: Message 4WT6yR2CyYzMrG5V from 67.219.246.153 (www-data@kamtopiaero.shop) to XXX.com is spam, SpamAssassin (not cached, score=44.223, required 4, autolearn=spam, BAYES_80 2.00, XXX_EXTERNAL 0.01, XXX_SPOOF 12.00, C_RBL_GBUDB 5.00, C_RBL_UCE_1 1.01, DATE_IN_PAST_03_06 1.59, DCC_CHECK 1.10, DCC_REPUT_95_98 1.00, DIGEST_MULTIPLE 0.29, DKIM_ADSP_ALL 0.80, FROM_IN_TO_AND_SUBJ 1.80, HEADER_FROM_DIFFERENT_DOMAINS 0.00, HTML_FONT_LOW_CONTRAST 0.00, HTML_MESSAGE 0.00, HTML_OBFUSCATE_10_20 0.09, KHOP_HELO_FCRDNS 0.26, MIME_HTML_ONLY 0.10, ML_SPAMINFO_EXISTS 5.00, MXPF_TEST 0.00, PYZOR_CHECK 1.39, RCVD_IN_PBL 3.33, RCVD_IN_SBL_CSS 3.33, SPF_HELO_SOFTFAIL 0.73, SPF_SOFTFAIL 0.67, TO_EQ_FM_HTML_ONLY 0.00, TO_IN_SUBJ 0.00, TO_NO_BRKTS_HTML_ONLY 2.00, TXREP -2.25, URIBL_ABUSE_SURBL 1.25, URIBL_BLACK 1.70)
I also found that over the last couple of days, there were 30 messages that fell into this hole.
My Spamassassin timeout is set to 120 seconds, which is plenty of time to resolve things on an lightly loaded server.
Unfortunately, there is nothing in the logs that tells me why it is timing out.
In case it was unbound causing the issues, I searched for timeout in /var/log/messages and I found 30 messages like the following:
so I think I've found the culprit.PHP Fatal error: Uncaught mysqli_sql_exception: Lock wait timeout exceeded; try restarting transaction in /var/www/html/mailscanner/functions.php:1066
3666 Jul 22 04:13:29 efa4 php: Stack trace:
3667 Jul 22 04:13:29 efa4 php: Fatal error: Uncaught mysqli_sql_exception: Lock wait timeout exceeded; try restarting transaction in /var/www/html/mailscanner/functions.php:1066
3668 Jul 22 04:13:29 efa4 php: Stack trace:
3669 Jul 22 04:13:29 efa4 php: #0 /var/www/html/mailscanner/functions.php(1066): mysqli->query('REPLACE INTO `m...')
3670 Jul 22 04:13:29 efa4 php: #1 /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_milter_relay.php(168): dbquery('REPLACE INTO `m...')
3671 Jul 22 04:13:29 efa4 php: #2 /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_milter_relay.php(58): process_sql()
3672 Jul 22 04:13:29 efa4 php: #3 /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_milter_relay.php(210): doit('cat /var/log/ma...')
3673 Jul 22 04:13:29 efa4 php: #4 {main}
Searching the /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_milter_relay.php code at line 168 shows that the system is doing an update on the mtalog_ids table which has 2.2 million records on my system.
I vaguely recall someone else having an issue with this table growing too large, and a quick search found the following: viewtopic.php?p=19809#p19809
I am going to clean out this table and see if that resolves the issue. I suspect it will.
