E.F.A. 3.0.0.4 update released
Posted: 17 Mar 2014 15:14
The following issues have been fixed in 3.0.0.4:
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
- Issue #65 Bug - Fix EFA-SA-Update file location
- Issue #63 Bug - Remove old kam.cf.backup from spamassasin directory
- Issue #18 Bug - Email signature sanitation (avoid duplicate signatures)
3) type:
