E.F.A. 3.0.0.4 update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
The following issues have been fixed in 3.0.0.4:
  • Issue #65 Bug - Fix EFA-SA-Update file location
  • Issue #63 Bug - Remove old kam.cf.backup from spamassasin directory
  • Issue #18 Bug - Email signature sanitation (avoid duplicate signatures)
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
Locked
