Hello
Quick question, how do you change the normal standard web port form 80?
ie, you access the server by http://[serveraddress]
I would like to be able to access this by http://[serveraddress]:8080
how do you change to port?
Andrew
						Change standard wed port
Re: Change standard wed port
I have not tested this but you will need to do a few things:
1) Edit apache config file (/etc/httpd/conf/httpd.conf) and change the Listen port to 8080 and restart apache
2) Edit the report files (/etc/MailScanner/reports/en/*) you will see that in a bunch of files there the variable $hostname is used, you should change this to reflect the new URL with the port in all the files
3) edit the QUARANTINE_REPORT_HOSTURL in the mailwatch config (/var/www/html/mailscanner/conf.php)
I believe that should be it.
I was hoping for a easier way!
I will look into this
Thanks for the information on how to do this.
Andrew
Andrew
