MailScanner: No programs allowed
Posted: 24 May 2023 09:23
by waltergarcia
How to Layer Customized T-Shirts for All Seasons
Having a lot of nice clothes might not be as important as knowing how to layer them, especially with special types of clothes like customized t-shirts. Whether you are a customized t-shirt lover or about to buy one, this is the right place for you. These tips for layering POD t-shirts for all types of weather and seasons can erase your fear of wearing a customized item in a boring way. And with this guide, you can Stay Ahead of All Trends with LionKingShirt Tees for Men and Women!
Layering your POD t-shirt for Spring
During spring, when the weather starts to get warmer, people usually wear light clothes. You can layer your customized t-shirts with a variety of springtime pieces. Start with a lightweight jacket. Denim jackets are a classic choice and pair well with just about any t-shirt design. They add a casual, cool vibe while keeping you comfortable when it’s a bit breezy outside.
Cardigans are another excellent option. Consider a soft, knit cardigan. It can keep you warm on cooler mornings and evenings and won’t make you overheat during the day. Choose one in a neutral color to let your t-shirt's design shine. If you want a pop of color, go for a pastel cardigan that complements the colors in your t-shirt.
Layering your customized t-shirt with a cardigan
I bet you sometimes use carves during spring. A light, airy scarf can add a bit of warmth and a touch of style. Go for a scarf in a contrasting color or a fun pattern that plays off your t-shirt’s design. It’s an easy way to add some personality and keep cozy without wearing a big jacket.
Layering your POD t-shirt for Summer
Things get different in the summer when sometimes it’s hot. This time, almost everyone goes for light and aired outfits. Therefore, layering in the heat is all about choosing the right materials and styles. Vests are a great option. A denim or utility vest can add some edge to your outfit without making you too hot. It also gives you some extra pockets, which is always a plus when going out and being active.
Lightweight button-down shirts are perfect for summer layering. Opt for linen or cotton fabrics that allow your skin to breathe. You can wear them open over your t-shirt for a relaxed, laid-back look. Roll up the sleeves for an extra touch of casual style.
Stylish cover-ups, like kimono-style jackets or sheer cardigans, are also excellent choices. They’re light and flowy, adding a layer of interest to your outfit without adding bulk. You can find these cover-ups in various prints and colors. One tip for you: try to choose the right size for your POD t-shirts and avoid ones that are too large if you want to wear them under cover-ups. Tight or fit cover-ups on the outside won’t look good with a large t-shirt inside. When shopping for a customized t-shirt at Lion King Tee Shirts, you will be provided with a sizing guideline to help you choose the right size.
Fall and Winter Layering
When the temperatures start to go down and the snow starts falling, it’s time to bring out the cozy layers. Customized t-shirts can still be a central part of your wardrobe, even in the colder months. Start with a flannel shirt. Wear a flannel shirt open over your t-shirt for a casual, laid-back look, or button it up and wear a puffer vest over both layers for extra warmth. The rugged, cozy vibe of flannel shirts matches your t-shirts well. This look is especially suitable for informal meetups and hangouts.
A flannel shirt can go well with your customized t-shirt
Coats are essential for winter, but they can also be a great layering piece. A classic trench coat or a stylish peacoat can add sophistication to your outfit. Make sure to choose a coat so that its colors are harmonious with your POD t-shirt. If you have complicated and colorful designs on your t-shirt, a neutral-toned outer layer is the best idea.
When you’ve done with your clothes, try putting on some accessories. Scarves, beanies, and gloves are classic - you shouldn’t miss out. A thick, knitted scarf can add warmth and style, especially if it’s in a color that contrasts with your t-shirt. Beanies are perfect for keeping your head warm and adding a casual, cozy vibe to your outfit.
Wrapping Things Up
If you have a cool and fashionable t-shirt, it’s good. But if you know how to layer it to wear all year round, it’s excellent. Whether it's a light jacket in spring, a vest in summer, a cozy sweater in fall, or a warm coat in winter, your customized t-shirts can be the star of your wardrobe if you know the how-to. At Lion King Shirt, t-shirts are not only perse in designs but also in styles, suitable for every season of the year.
Re: MailScanner: No programs allowed
Posted: 24 May 2023 11:41
1/ Are you 100% sure they are docx files?
Because docx are not executable and shouldn't be detectable as executable files.
Run the following command on your EFA box and report back the results
grep -ir "No programs allowed" /etc/MailScanner/
2/ What do you mean by "removing signatures"? I don't understand what you did so I would like to understand to see if that will create a problem for you or not.
Posted: 21 Nov 2023 15:04
by omer
I started having a similar problem. Shapefile format is a format used for geographic information systems. This creates an archive and contains files with extensions such as .dbf, .prj, .sbn, .sbx, .shp, .shx.
But Efa-Project prevents this.
How can I get over this ending?
MailScanner: No programs allowed (GS_Boundary.dbf)
MailScanner: No programs allowed (GS_Boundary.dbf) MailScanner: No programs allowed (GS_Boundary)
Thank you.
Posted: 26 Nov 2023 02:34
by tochiwa94
Maybe try this workaround from an old post in this forum and see if it works:
viewtopic.php?t=2893:
sudo vi /etc/MailScanner/filename.rules.conf ... and archives.filename.rules.conf
-- Before the final deny add in "Allow \.ics$ - -". Tab separated, make sure you don't get these as spaces. I added this as ics (calendar) files can have odd names which trip up mailscanner.
Posted: 26 Nov 2023 08:42
by omer
I already tried this but without success.
Posted: 26 Nov 2023 09:44
by omer
My config files are as follows.
No matter what I did, it didn't work. It also blocks it when it is in Zip or RAR.
archives.filetype.rules.conf - https://pastebin.com/kqtnXDQv
filetype.rules.conf - https://pastebin.com/VFnDppnq
filename.rules.conf - https://pastebin.com/DY8Jzbsx
