Hello!
How to allow via efa sending of signed docx files?
After scanning, these files are treated as "MailScanner: No programs allowed".
When removing signatures, all is ok.
Re: MailScanner: No programs allowed
1/ Are you 100% sure they are docx files?
Because docx are not executable and shouldn't be detectable as executable files.
Run the following command on your EFA box and report back the results
2/ What do you mean by "removing signatures"? I don't understand what you did so I would like to understand to see if that will create a problem for you or not.
grep -ir "No programs allowed" /etc/MailScanner/
