Default MYSQL Credentials
curibe
Post by curibe »
What are the Default MYSQL credentials that comes with the build?
for some reason i have the wrong credentials in webmin >servers > MySql Database Server. i keep seen this error "he full MySQL error message was : DBI connect failed : Access denied for user 'whadmin'@'localhost' (using password: YES)"
Also for MailWatch i cant log in because i do not have the right credentials in SQL.
I get the same error witch i think it could be related "Could not connect to database: Access denied for user 'mailwatch'@'localhost' (using password: YES)"
Please let me know.
Re: Default MYSQL Credentials
Take a peek in /etc/EFA-Config
:D
curibe
Post by curibe »
Hmm i tried those long string PW but i still cant log in.
anyway to change the config file and rerun the config?
sorry, im just new at this. ;)
whadmin is not a SQL user in EFA...
This may help
Here are the SQL user accounts:
root and sa-user -- all databases
mailwatch -- mailwatch database only
sqlgrey -- sqlgrey database only
efa -- efa database only
curibe
Post by curibe »
I just tried using the sa-user with the SAUSERSQLPWD and it does not let me in.
I also tried with root and the mysqlrootpwd
Please post the command you are trying to execute without the password.
curibe
Post by curibe »
what i did was recreate the appliance. i did not upgrade to latest version of EFA-3.0.0.2. i was able to log into mysql server from webmin. this allowed me to create a user that will allow me to log into mailwatch.
maybe i bombed my first install of EFA :) but the second one works great. or maybe the upgrade had something to do with it. would it? Should i upgrade to EFA-3.0.0.2?
let me know.
curibe wrote:what i did was recreate the appliance. i did not upgrade to latest version of EFA-3.0.0.2. i was able to log into mysql server from webmin. this allowed me to create a user that will allow me to log into mailwatch.
Firstly, EFA-Init should have created a MailWatch user for you. That user would be the non-root user. Did it not create the user?
I would hold of on applying 3.0.0.2. We are close to releasing 3.0.0.3 which includes fixes after 3.0.0.2 was released.
