update fails
grant
update fails
Post by grant »
Failed to download metadata from repo appstream.
Please see attached screenshot.
Gratitude...
freyuh
Re: update fails
Post by freyuh »
Hello grant,
look at this post: viewtopic.php?f=19&t=4888
The parameter failovermethod is obsolete and has to be disabled/removed.
Ulrich.
grant
Re: update fails
Post by grant »
@freyuh
Which line to comment, please? In which file?
Re: update fails
Did you read the post mentioned in the message above yours? The file and line is explained there.
Hint:
root@efa4 ~]# cd /etc/yum.repos.d/
[root@efa4 yum.repos.d]# vi eFa4.repo
