Spam from cloud blacklist passing through eFA
Posted: 24 Mar 2022 07:31
by viper407
Good morning
I have certain emails coming through and ESET is catching it after eFA passes it onto Exchange.
How do i block emails as per the attached and have eFA check that IP's are on a blacklist?
Thank you
Edward
Re: Spam from cloud blacklist passing through eFA
Posted: 24 Mar 2022 08:16
by freyuh
Is this a public or ESET internal Blacklist?
If it's public maybe it can be added to the postfix config ...
Ulrich.
Posted: 24 Mar 2022 08:30
by viper407
Hi Ulrich
It is public. Where would this be added in the postfix config to do a check on an IP for blacklisting?
Kind Regards
Edward
Posted: 24 Mar 2022 10:37
by freyuh
Hello Edward,
as I told you in your other post: Search the forum for "reject_rbl_client".
reject_rbl_client <address of blacklist-server>
Ulrich.
Posted: 24 Mar 2022 16:56
by viper407
Hello Ulrich
Thank you,
I found some more than what I had and implemented it but it blocked outlook.com and gmail.com as they are on blacklists so had to remove the 4 entries i added. Will put them back as soon as i get the go-ahead again.
