Good morning
I have certain emails coming through and ESET is catching it after eFA passes it onto Exchange.
How do i block emails as per the attached and have eFA check that IP's are on a blacklist?
Thank you
Edward
Spam from cloud blacklist passing through eFA
- blacklist.png (4.01 KiB) Viewed 7089 times
Re: Spam from cloud blacklist passing through eFA
Is this a public or ESET internal Blacklist?
If it's public maybe it can be added to the postfix config ...
Ulrich.
Ulrich.
Hi Ulrich
It is public. Where would this be added in the postfix config to do a check on an IP for blacklisting?
Kind Regards
Edward
Kind Regards
Edward
Hello Edward,
as I told you in your other post: Search the forum for "reject_rbl_client".
reject_rbl_client <address of blacklist-server>
Ulrich.
Ulrich.
Hello Ulrich
Thank you,
I found some more than what I had and implemented it but it blocked outlook.com and gmail.com as they are on blacklists so had to remove the 4 entries i added. Will put them back as soon as i get the go-ahead again.
Thank you,
