How to prevent EFA to change the "mail from" address when deliver quarantined messages
andregrehs
Post by andregrehs »
Hi!
When i choose to deliver quarantined messages to final recipient, the EFA change the original mail from address to no-reply@antispam.example.com, and deliver the original message attached at the e-mail.
How i prevent this?
I want that the EFA, when the admin choose to deliver the quarantined message, deliver the message to recipent as original, without change the mail from address.
MailWatch Version: 1.2.16
Postfix Version: 3.5.9
MailScanner Version: 5.4.1
ClamAV Version: 0.103.3
SpamAssassin Version: 3.4.6
PHP Version: 7.4.21
MySQL Version: 10.2.30-MariaDB
GeoIP Database Version: No database downloaded
Mail2GoCa
Re: How to prevent EFA to change the "mail from" address when deliver quarantined messages
Post by Mail2GoCa »
Edit /var/www/html/mailscanner/conf.php and look for the below code and make sure that "QUARANTINE_USE_SENDMAIL" is set to true.
// Set QUARANTINE_USE_SENDMAIL to true to send released email as original email using sendmail,
// false to send it as an attachment to a release message.
define('QUARANTINE_USE_SENDMAIL', true);
define('QUARANTINE_SENDMAIL_PATH', '/usr/sbin/sendmail');
/* End Quarantine settings */
andregrehs
That's exactly what I needed. Thank you so much for your help. Success on your journey, friend. :clap: :clap: :clap:
Aryfir
Post by Aryfir »
Login to this forum just to say THANK YOU Mail2GoCa.....Didn't know that the config is in web folder
Regards,
Ary Firman
The_Penguin
Post by The_Penguin »
Hi all. Does this still apply to MailWatch for MailScanner v1.2.23 running on eFa-5.0.0-11?
I tried it and it didn't change for me unless I missed something. I did restart MailScanner and httpd.
Mail2GoCa
Post by Mail2GoCa »
Hi Penguin,
Yes it's still the same.
The_Penguin
Thanks for the confirmation.
Turns out I missed the existing entry in the file and created a new one.
Corrected that and it's working as desired.
Mail2GoCa
Post by Mail2GoCa »
Excellent. Glad you're all set.
