only accept mail from efa users?
Is there a way to make efa automatically drop mail for users that do not exist within it, instead of it actually hitting the mail server then rejecting?
Re: only accept mail from efa users?
The quickest way is probably to create a relay_recipients list in postfix. You can build it by hand, or if you have AD, check out this thread...
http://forum.efa-project.org/viewtopic.php?f=14&t=433
