Clamd::ERROR:: Access denied after TNEF expansion
victorburgos
Post by victorburgos »
I have seen in my server logs "Access denied" errors from Clamd.
These errors allways appears after a TNEF archive expansion.
error clamd.png (141.73 KiB) Viewed 2645 times
Ownership of /var/spool/MailScanner/incoming/
[user@]# ls -l /var/spool/MailScanner/
total 0
drwxrwxr-x.  2 root    mtagroup   6 Dec  7 12:01 archive
drwxrwx---. 25 root    mtagroup 540 Jan 22 01:01 incoming
drwxrwxr-x.  2 postfix postfix   30 Jan 22 01:01 milterin
drwxrwxr-x.  2 postfix postfix    6 Jan 22 00:59 milterout
drwxrwxr-x. 18 postfix mtagroup 262 Jan 22 00:01 quarantine
drwxrwx---.  5 root    mtagroup 112 Jan 21 20:59 ramdisk_store
drwxr-xr-x.  2 postfix mtagroup   6 Oct 29 23:57 spamassassin
Ownership inside incoming:
[user@]# ls -l /var/spool/MailScanner/incoming/
total 2460
drwxrwx---. 3 postfix mtagroup     100 Jan 22 00:58 14651
drwxrwx---. 2 apache  mtagroup      40 Oct 30 00:30 clamav-tmp
drwxr-xr-x. 2 root    postfix      240 Jan 21 20:59 Locks
-rw-------. 1 postfix postfix    43008 Jan 22 00:58 Processing.db
-rw-------. 1 postfix postfix  2471936 Jan 22 00:57 SpamAssassin.cache.db
drwxr-xr-x. 2 postfix root         100 Jan 22 00:58 SpamAssassin-Temp
Settings in /etc/MailScanner/MailScanner.conf
Run As User = postfix
Run As Group = postfix
Incoming Work Group = mtagroup
Incoming Work Permissions = 0660
Expand TNEF = yes
Use TNEF Contents = replace
Deliver Unparsable TNEF = yes
TNEF Expander = /usr/bin/tnef --maxsize=100000000
TNEF Timeout = 120
Settings in /etc/clamd.d/scan.conf
User clamscan
Clamscan is member of mtagroup
[user@]# grep mtagroup /etc/group
mtagroup:x:1001:clamscan,php-fpm,apache,postfix
Thanks for your help.
