incorrect apache config
bbrendon
Post by bbrendon »
This should be done the "debian" way I think. These files should be the same. The main file should be in available, and a link to that file should be in enabled. There is a command in debian a2ensite to manage these.
root@mailsort:/etc/apache2# diff sites-available/baruwa sites-enabled/baruwa
12d11
<     ServerName localhost.localdomain
darky83
Site Admin
Re: incorrect apache config
Post by darky83 »
Yea it should actually but this is how the 'baruwa config' configures apache.
I don't want to change this as it might break future baruwa updates (it is marked as a bug in baruwa btw)
d.
