When Box starts for about 10 seconds is unable to accept mail i suppose that unbuund need to be active
is possiboe to start it first by default ?
mailsend -f nicola.piazzi@g*t.it -t check-auth@verifier.port25.com -M CORPO -sub TESTDKIM -smtp efa42.gruppocomet.it
Error: RCPT TO: <check-auth@verifier.port25.com> failed '450:4.1.8 <nicola.piazzi@g*t.it>: Sender address rejected: Domain not found'
Could not send mail
Mail sent successfully
unbound priority start
Re: unbound priority start
When you want to see the what is happening on boot ( errors/warnings)
1.
look at
2.
3.
and
4. Use systemd-analyze
Take a look at this post viewtopic.php?t=3861
1.
dmesg2.
/var/log/boot.logCode: Select all
/var/log/messages4. Use systemd-analyze
