E.F.A. 3.0.0.1 update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
The following issues have been addressed in E.F.A. 3.0.0.1 :
  • Correct length check for ID in learn-msg.cgi
  • Add option to configure cleaned message delivery
  • Fix sql_select option missing and auxpropfunc errors
  • Enable quarantine cleanup
  • Add https/ssl/tls configuration options for Apache
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
Locked
